[GRASS-dev] [GRASS GIS] #2246: G7: r.shaded.relief result not added to layer tree
trac at osgeo.org
Mon Apr 7 14:10:24 PDT 2014
Reporter: neteler | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: wxGUI | Version: svn-releasebranch70
Keywords: r.shaded.relief | Platform: Linux
Cpu: x86-64 |
When calculating a shaded map with r.shaded.relief,
the resulting map is not added to the map layer tree.
I used "elevation at PERMANENT", NC location
The shaded map is calculated but not added.
g.version -g
version=7.0.0svn
date=2014
revision=59520
build_date=2014-03-30
build_platform=x86_64-unknown-linux-gnu
Ticket URL: <http://trac.osgeo.org/grass/ticket/2246>
