[GRASS-dev] [Qgis-developer] GRASS & QGIS: the future
    Radim Blazek
    radim.blazek at gmail.com
    Tue Apr  8 07:03:10 PDT 2014
On Tue, Apr 8, 2014 at 3:54 PM, Rainer M Krug <Rainer at krugs.de> wrote:
> Radim Blazek <radim.blazek at gmail.com> writes:
>> On Tue, Apr 8, 2014 at 2:18 PM, Moritz Lennert
>> <mlennert at club.worldonline.be> wrote:
>>> On 28/03/14 15:16, Paolo Cavallini wrote:
>>>> Il 28/03/2014 15:04, Martin Dobias ha scritto:
>>>>> On Fri, Mar 28, 2014 at 11:48 AM, Paolo Cavallini <cavallini at faunalia.it>
>>>>> wrote:
>>>>>> * to add GRASS browsing capabilities in QGIS file browser
>>>>> The support for GRASS is already in the browser - if you enter a
>>>>> directory that is a GRASS database, it will detect it and show
>>>>> locations/mapsets/maps/layers.
>>>> That's great news, never tried. Works beautifully, thanks.
>>> I cannot reproduce this. How does it work exactly ? When I browse into a
>>> GRASS database directory, it just shows up like any other directory.
>> The GRASS location is added as another item with GRASS icon in the
>> tree on the same level where is the location dir. It means that the
>> location will appear twice, first as regular dir and then as a GRASS
>> location. The items do not seem to be sorted by name, so maybe you
>> have to scroll down.
> Hm - I think I also need a step-by-step guide. I am using QGIS 2.2.0 on
> OSX Maverick and I don't get it to work.
> 0) Open QGIS
> 1) I open the browser (View - Panels - Browser)
> 2) Then I go via the Home folder (top entry) to a GRASS database
> 3) and now, where should I see what? What is the root in the tree
> structure? I can only see the folder structure.
Probably a bug. It is checking for location/PERMANENT/DEFAULT_WIND.
You have maybe lower case names? If so, can you test with upper?
Please fill a new issue.
Radim
> Rainer
>> Radim
>>> Moritz
>>> grass-dev mailing list
>>> grass-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/grass-dev
> Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology, UCT), Dipl. Phys. (Germany)
> Centre of Excellence for Invasion Biology
> Stellenbosch University
> South Africa
> Tel :       +33 - (0)9 53 10 27 44
> Cell:       +33 - (0)6 85 62 59 98
> Fax :       +33 - (0)9 58 10 27 44
> Fax (D):    +49 - (0)3 21 21 25 22 44
> email:      Rainer at krugs.de
> Skype:      RMkrug
> PGP: 0x0F52F982
