[GRASS-dev] [Qgis-developer] GRASS & QGIS: the future
Rainer M Krug
Rainer at krugs.de
Tue Apr 8 06:54:46 PDT 2014
Radim Blazek <radim.blazek at gmail.com> writes:
> On Tue, Apr 8, 2014 at 2:18 PM, Moritz Lennert
> <mlennert at club.worldonline.be> wrote:
>> On 28/03/14 15:16, Paolo Cavallini wrote:
>>> Il 28/03/2014 15:04, Martin Dobias ha scritto:
>>>> On Fri, Mar 28, 2014 at 11:48 AM, Paolo Cavallini <cavallini at faunalia.it>
>>>> wrote:
>>>>> * to add GRASS browsing capabilities in QGIS file browser
>>>> The support for GRASS is already in the browser - if you enter a
>>>> directory that is a GRASS database, it will detect it and show
>>>> locations/mapsets/maps/layers.
>>> That's great news, never tried. Works beautifully, thanks.
>> I cannot reproduce this. How does it work exactly ? When I browse into a
>> GRASS database directory, it just shows up like any other directory.
> The GRASS location is added as another item with GRASS icon in the
> tree on the same level where is the location dir. It means that the
> location will appear twice, first as regular dir and then as a GRASS
> location. The items do not seem to be sorted by name, so maybe you
> have to scroll down.
Hm - I think I also need a step-by-step guide. I am using QGIS 2.2.0 on
OSX Maverick and I don't get it to work.
0) Open QGIS
1) I open the browser (View - Panels - Browser)
2) Then I go via the Home folder (top entry) to a GRASS database
3) and now, where should I see what? What is the root in the tree
structure? I can only see the folder structure.
Rainer
> Radim
>> Moritz
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology, UCT), Dipl. Phys. (Germany)
Centre of Excellence for Invasion Biology
Stellenbosch University
South Africa
Tel : +33 - (0)9 53 10 27 44
Cell: +33 - (0)6 85 62 59 98
Fax : +33 - (0)9 58 10 27 44
Fax (D): +49 - (0)3 21 21 25 22 44
email: Rainer at krugs.de
Skype: RMkrug
PGP: 0x0F52F982
Name: not available
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140408/28b671e8/attachment.pgp>
