[GRASS-dev] relbr6 - devbr6 differences
Benjamin Ducke
benducke at fastmail.fm
Wed Apr 9 01:52:59 PDT 2014
GEOS is a heavy C++ beast and difficult to compile using GCC
on Windows (at least if you want the result to pass all
validation tests).
I would prefer to stick to C dependencies only for the core
modules, if only to avoid DLL hell when mixing Visual C++
and GCC DLLs on Windows (different name mangling styles).
Ben
On 09/04/14 09:36, Moritz Lennert wrote:
> On 09/04/14 08:35, Martin Landa wrote:
>> Hi Markus,
>> 2014-04-09 8:28 GMT+02:00 Markus Metz <markus.metz.giswork at gmail.com>:
>>> - wxGUI backport?
>> will take a look...
>>> - v.buffer differs, but is broken in both branches. Only the
>>> GEOS-enabled version in G7 works. Since this is a bugfix, I would
>>> suggest to backport v.buffer from G7 to G6.
> +1
> If GEOS thus becomes a mandatory dependency, this will also
> automatically enable the additional operators in v.select which I think
> is a good thing.
> Moritz
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
Dr. Benjamin Ducke, M.A.
{*} Geospatial Consultant
{*} GIS Developer
