[GRASS-dev] relbr6 - devbr6 differences
Jürgen E. Fischer jef at norbit.de
Wed Apr 9 02:44:13 PDT 2014
On Wed, 09. Apr 2014 at 10:52:59 +0200, Benjamin Ducke wrote:
> GEOS is a heavy C++ beast and difficult to compile using GCC
> on Windows (at least if you want the result to pass all
> validation tests).
> I would prefer to stick to C dependencies only for the core
> modules, if only to avoid DLL hell when mixing Visual C++
> and GCC DLLs on Windows (different name mangling styles).
That's why GEOS has a C API.  Doesn't GRASS use that anyway?
Jürgen
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-31
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden               http://www.norbit.de
QGIS PSC member (RM)      Germany                      IRC: jef on FreeNode
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
