[GRASS-dev] TOC in the manual
Anna Petrášová kratochanna at gmail.com
Fri Apr 11 15:27:26 PDT 2014
Note, that on Windows and on Ubuntu with wxPython 3, the manual page in the
tab is loaded immediately. I believe we should keep the manual in the tab,
I think people are more likely to look at the manual there than pressing
Help button. Personally I try to avoid pressing Help button in any
application, it usually takes a lot of time to start browser and load it.
WxPython 3 has some new widget for websites so eventually, it could replace
the widget we use now.
Anna
On Fri, Apr 11, 2014 at 6:49 AM, Yann Chemin <ychemin at gmail.com> wrote:
> Did not have an opinion fixed, so went back to work, opened a module,
> pressed on the manual tab and did have to wait a bit because of
> rendering... If it was to open in a default web browser, I could have
> continued looking around the module.
> +1 for button to external browser
> On 11 April 2014 14:33, Martin Landa <landa.martin at gmail.com> wrote:
>> Hi,
>> 2014-04-11 10:38 GMT+02:00 Martin Landa <landa.martin at gmail.com>:
>> > body part is 80%, see eg. [1]. Since wxPython widget doesn't support
>> > most of css, it's shown before DESCRIPTION and not as fixed.
>> the question is whether to hide manual tab and just to provide button
>> which opens manual in the web browser. Martin
>> Martin Landa * http://geo.fsv.cvut.cz/gwiki/Landa
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140411/ed92dcee/attachment.html>
