[GRASS-dev] TOC in the manual
Yann Chemin
ychemin at gmail.com
Fri Apr 11 18:02:29 PDT 2014
+1
On 12 April 2014 03:57, Anna Petrášová <kratochanna at gmail.com> wrote:
> Note, that on Windows and on Ubuntu with wxPython 3, the manual page in
> the tab is loaded immediately. I believe we should keep the manual in the
> tab, I think people are more likely to look at the manual there than
> pressing Help button. Personally I try to avoid pressing Help button in any
> application, it usually takes a lot of time to start browser and load it.
> WxPython 3 has some new widget for websites so eventually, it could replace
> the widget we use now.
> Anna
> On Fri, Apr 11, 2014 at 6:49 AM, Yann Chemin <ychemin at gmail.com> wrote:
>> Did not have an opinion fixed, so went back to work, opened a module,
>> pressed on the manual tab and did have to wait a bit because of
>> rendering... If it was to open in a default web browser, I could have
>> continued looking around the module.
>> +1 for button to external browser
>> On 11 April 2014 14:33, Martin Landa <landa.martin at gmail.com> wrote:
>>> Hi,
>>> 2014-04-11 10:38 GMT+02:00 Martin Landa <landa.martin at gmail.com>:
>>> > body part is 80%, see eg. [1]. Since wxPython widget doesn't support
>>> > most of css, it's shown before DESCRIPTION and not as fixed.
>>> the question is whether to hide manual tab and just to provide button
>>> which opens manual in the web browser. Martin
>>> Martin Landa * http://geo.fsv.cvut.cz/gwiki/Landa
>>> grass-dev mailing list
>>> grass-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140412/d082e39a/attachment.html>
