[GRASS-dev] [GRASS GIS] #2138: winGRASS6.4.svn - addon python	script status?
    trac at osgeo.org
    Fri Apr 18 05:16:14 PDT 2014
  Reporter:  hellik       |       Owner:  martinl
      Type:  defect       |      Status:  reopened
  Priority:  critical     |   Milestone:  6.4.4
 Component:  Addons       |     Version:  svn-releasebranch64
Resolution:               |    Keywords:  wingrass, addon, python
  Platform:  MSWindows 7  |         Cpu:  x86-64
Comment(by hellik):
 Replying to [comment:22 martinl]:
 > how you managed that? When I type to wxGUI console `r.basin`, press
 Enter, fill all parameters and press Start button than the command is
 launched correctly (so without .py extension)
 very strange ...
 System Info
 GRASS Version: 6.4.4svn
 GRASS SVN Revision: 59777
 GDAL/OGR: 1.10.1
 PROJ4: Rel. 4.8.0, 6 March 2012
 Python: 2.7.4
 wxPython: 2.8.12.1
 Platform: Windows-Vista-6.0.6002-SP2 (OSGeo4W)
 can test it later on on my win7-box
 (1)
 no addons in C:\Users\xxxx\AppData\Roaming\GRASS6
 (2)
 fetch and install addons => ok
 addons are now in C:\Users\xxxx\AppData\Roaming\GRASS6 => ok
 (3)
 python addon script-related bat-files => ok
 e.g.
 @"%GRASS_PYTHON%" "%GRASS_ADDON_PATH%/r.basin.py" %*
 (3)
 wxGUI console `r.basin`, press Enter => r.basin-wxgui pops up => ok
 (4)
 fill all parameters and press Start button of r.basin-wxgui => r.basin-
 wxgui command output
 r.basin.py map=elevation at PERMANENT prefix=n easting=636654.791181
 northing=218824.126649
 C:\OSGeo4W\bin\python.exe: can't open file 'r.basin.py':
 [Errno 2] No such file or directory
 (Fri Apr 18 14:11:31 2014) Befehl ausgeführt (0 Sek)
Ticket URL: <http://trac.osgeo.org/grass/ticket/2138#comment:23>
