[GRASS-dev] [GRASS GIS] #2138: winGRASS6.4.svn - addon python script status?
trac at osgeo.org
Fri Apr 18 05:24:00 PDT 2014
Reporter: hellik | Owner: martinl
Type: defect | Status: reopened
Priority: critical | Milestone: 6.4.4
Component: Addons | Version: svn-releasebranch64
Resolution: | Keywords: wingrass, addon, python
Platform: MSWindows 7 | Cpu: x86-64
Comment(by hellik):
Replying to [comment:22 martinl]:
> Replying to [comment:21 hellik]:
> > e.g. r.basin start by typing r.basin in the wxgui-commandline, then
enter all parameters und press the start button in the
> > r.basin-wxgui:
> > r.basin.py --verbose map=elevation at PERMANENT prefix=l
easting=636654.791181 northing=218824.126649 threshold=20
> how you managed that? When I type to wxGUI console `r.basin`, press
Enter, fill all parameters and press Start button than the command is
launched correctly (so without .py extension)
this was already in my original report (see also above):
r.basin-gui can be invoked, but running the script by 'run' in the r
.basin-wxgui raises following error
r.basin.py --verbose map=elevation at PERMANENT prefix=oh
C:\OSGEO4~1\bin\python.exe: can't open file 'r.basin.py':
[Errno 2] No such file or directory
(Sun Nov 24 15:47:59 2013) Befehl ausgeführt (0 Sek)
AFAIR tested on different windows boxes (vista, 7, 8) with same results
any idea?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2138#comment:24>
