[GRASS-dev] [GRASS GIS] #2138: winGRASS6.4.svn - addon python script status?
trac at osgeo.org
Fri Apr 18 07:20:56 PDT 2014
Reporter: hellik | Owner: martinl
Type: defect | Status: reopened
Priority: critical | Milestone: 6.4.4
Component: Addons | Version: svn-releasebranch64
Resolution: | Keywords: wingrass, addon, python
Platform: MSWindows 7 | Cpu: x86-64
Comment(by martinl):
Replying to [comment:28 wenzeslaus]:
> To be honest I would not expect that `r.basin.py` would work. It should
be enough that `r.basin` works. The name of the module is `r.basin` and
only this will work for all platforms, so I don't think it would be
beneficial if some people would write `r.basin` and some `r.basin.py`.
The problem was that if you launched the command from the dialog (fill
parameter and press Start button) than it was calling `r.basin.py` instead
of `r.basin`. It should be fixed now.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2138#comment:29>
