[GRASS-dev] Week 11: GRASS GIS 3D flowlines
Anna Petrášová kratochanna at gmail.com
Fri Aug 1 12:54:25 PDT 2014
1. What did you get done this week:
I implemented adding attributes to each segment of a flowline. I added
column with velocities and values of input 3D raster along the flowline.
The result can be visualized by using vector color tables (v.colors) in 2D
and 3D.
I started writing r3.gradient module based on the gradient function in
r3.flow. The module is already running and giving correct results, I will
add it to addons once the gradient function is moved to library.
2. What do you plan on doing next week?
I will try to parallelize the gradient computation with openMP, the
structure of the code is already prepared for that. Then, I plan to add
more tests.
3. Are you blocked on anything?
No.
Anna
[1]
http://trac.osgeo.org/grass/wiki/GSoC/2014/ImplementationOf3DRasterFlowLine
[2] http://trac.osgeo.org/grass/browser/grass-addons/grass7/raster3d/r3.flow
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140801/22abefe8/attachment.html>
