[GRASS-dev] Week 11: GRASS GIS 3D flowlines
Newcomb, Doug
doug_newcomb at fws.gov
Thu Aug 7 04:59:07 PDT 2014
Anna,
This parallels my experience in running v.surf.rst with OpenMP enabled and
disabled on large areas. With OpenMP enabled on an 8 core computer, the
process used 700% of CPU time, but took about twice as long as running the
same data set on a single core with OpenMP disabled.
Doug
On Wed, Aug 6, 2014 at 10:58 PM, Anna Petrášová <kratochanna at gmail.com>
wrote:
> Hi,
> On Tue, Aug 5, 2014 at 11:04 AM, Newcomb, Doug <doug_newcomb at fws.gov>
> wrote:
>> Anna,
>> Will you post the benchmarking results for the OpenMP computation vs
>> the non-OpenMP?
> after some testing, my conclusion is that OpenMP does not really speed up
> gradient computation and it can even slow it down. I tried it on my laptop
> with 2 cores and on a powerful computer with 12 cores, with different sizes
> of processed blocks and I didn't get any significant speed-up. The most
> costly seems to be writing of the three 3D rasters and the gradient
> computation is relatively short. I also tested different cache settings but
> default settings seems to be optimal, I got only similar or worse results
> with different cache settings. I hope I didn't missed anything, since this
> is quite new to me.
> Best,
> Anna
> Doug
>> On Fri, Aug 1, 2014 at 3:54 PM, Anna Petrášová <kratochanna at gmail.com>
>> wrote:
>>> Hi,
>>> 1. What did you get done this week:
>>> I implemented adding attributes to each segment of a flowline. I added
>>> column with velocities and values of input 3D raster along the flowline.
>>> The result can be visualized by using vector color tables (v.colors) in 2D
>>> and 3D.
>>> I started writing r3.gradient module based on the gradient function in
>>> r3.flow. The module is already running and giving correct results, I will
>>> add it to addons once the gradient function is moved to library.
>>> 2. What do you plan on doing next week?
>>> I will try to parallelize the gradient computation with openMP, the
>>> structure of the code is already prepared for that. Then, I plan to add
>>> more tests.
>>> 3. Are you blocked on anything?
>>> No.
>>> Anna
>>> [1]
>>> http://trac.osgeo.org/grass/wiki/GSoC/2014/ImplementationOf3DRasterFlowLine
>>> [2]
>>> http://trac.osgeo.org/grass/browser/grass-addons/grass7/raster3d/r3.flow
>>> grass-dev mailing list
>>> grass-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/grass-dev
>> Doug Newcomb
>> USFWS
>> Raleigh, NC
>> 919-856-4520 ext. 14 doug_newcomb at fws.gov
>> The opinions I express are my own and are not representative of the
>> official policy of the U.S.Fish and Wildlife Service or Dept. of the
>> Interior. Life is too short for undocumented, proprietary data formats.
Doug Newcomb
USFWS
Raleigh, NC
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140807/375ee423/attachment.html>
