[GRASS-dev] measuring cpu time for each module and estimating modules scalability
Jachym Cepicky
jachym.cepicky at gmail.com
Fri Aug 8 04:00:36 PDT 2014
Hi all,
just some intellectual thoughts for the weekend (I'm off for a
weekend, so no need to rush with the answer). I started to write some
script [1], which tries to estimate CPU time, needed for each GRASS
module (currently, I have about 4-5 raster modules). Target is to
create suit (rather then simple script), which could estimate how each
process scales (based on number of features or raster cells, which
need to be processed) and put GRASS modules into row. Also estimate
rawly CPU time, which is consumed by each module.
Any thoughts to this?
I started with the dataset from Martin [2], but I thing, I'll switch
over to spearfish, one resolution for now. I did not figure out yet,
how to implement equivalent of unix time [3] program in Python
Thanks
Jachym
[1] https://github.com/jachym/grass-performace
[2] http://geo.fsv.cvut.cz/data/grasswikicz/freegeodatacz/aktualni/
[3] https://github.com/jachym/grass-performace
Jachym Cepicky
e-mail: jachym.cepicky gmail com
URL: http://les-ejk.cz
GPG: http://les-ejk.cz/pgp/JachymCepicky.pgp
Give your code freedom with PyWPS - http://pywps.wald.intevation.org
