[GRASS-dev] Week 12: GRASS GIS 3D flowlines
Anna Petrášová
kratochanna at gmail.com
Fri Aug 8 15:49:35 PDT 2014
1. What did you get done this week:
I added gradient function to 3D raster library and than added r3.gradient
[3] module to addons. I tested it with and without OpenMP and it seems that
OpenMP doesn't really speed up the module, it usually slows it down. So I
will probably remove the OpenMP support completely. I also tried different
settings of cache but again, I found no significant improvement with other
than default settings. Then, I added more tests for r3.flow (and fixed a
bug) and r3.gradient. In the gradient function, I also added better
handling for NULL values.
2. What do you plan on doing next week?
I will move both modules in trunk next week. I will update manual pages.
3. Are you blocked on anything?
No.
Anna
[1]
http://trac.osgeo.org/grass/wiki/GSoC/2014/ImplementationOf3DRasterFlowLine
[2] http://trac.osgeo.org/grass/browser/grass-addons/grass7/raster3d/r3.flow
[3] http://trac.osgeo.org/grass/browser/grass-addons/grass7/raster3d/r3.
<http://trac.osgeo.org/grass/browser/grass-addons/grass7/raster3d/r3.flow>
gradient
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140808/2ef30c0f/attachment.html>
