[GRASS-dev] GRASS 7 add-ons on Mac OSX (10.9)
Johannes Radinger
johannesradinger at gmail.com
Fri Aug 15 12:17:08 PDT 2014
On Fri, Aug 15, 2014 at 6:07 PM, Markus Neteler <neteler at osgeo.org> wrote:
> On Fri, Aug 15, 2014 at 5:56 PM, Anna Petrášová <kratochanna at gmail.com>
> wrote:
> > On Fri, Aug 15, 2014 at 11:07 AM, Johannes Radinger
> > <johannesradinger at gmail.com> wrote:
> >> Hi,
> >> I try to install add-ons on GRASS GIS 7 beta on Mac OSX (10.9).
> >> G7 has been installed including all frameworks from
> >> http://grassmac.wikidot.com/downloads
> >> (snapshot from 11.08.2014, GRASS 7.0.0svn (r61585M)).
> > I tested r.fuzzy.system on Windows and Mac and it's working for me...
> > This part is weird:
> > /bin/sh: Radinger-2668/gisrc: No such file or directory
> It simply comes from the white space in the path (and above shows only
> the second part):
> ERROR: Compilation failed, sorry. Please check above error messages.
> if [
> "/var/folders/z6/kpf8b53j04vcgq71ycrqzs040000gq/T/tmptRWIEo/r.fuzzy.system/bin/r.fuzzy.system"
> != "" ] ; then
> GISRC=/var/folders/z6/kpf8b53j04vcgq71ycrqzs040000gq/T/grass7-Johannes
> Radinger-2668/gisrc
> --> "...Johannes Radinger..."
> So some proper quoting will be missing.
Which needs to be corrected within "g.extension"? Or is there anything I
can do myself from a user's point?
Johannes
> Markus
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140815/19476be9/attachment.html>
