[GRASS-dev] [GRASS GIS] #2392: winGRASS GIS 6.4.5 svn r.li modules - issues with hard coded path to conf files
trac at osgeo.org
Sun Aug 17 08:58:57 PDT 2014
files
Reporter: hellik | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 6.4.5
Component: Raster | Version: svn-releasebranch64
Keywords: wingrass, r.li | Platform: MSWindows 7
Cpu: x86-32 |
Comment(by neteler):
Replying to [ticket:2392 hellik]:
> from the ML
> http://lists.osgeo.org/pipermail/grass-dev/2014-August/070384.html
> now conf-file generated in winGRASS7.1svn and the conf file stored e.g.
> C:\Users\normal\AppData\Roaming\GRASS6\movwindow7
Note that the r.li directory is different in GRASS GIS 6 from than what
you tried:
# Linux
$HOME/.r.li/history/movwindow7
# Windows (untested, please test)
C:\Users\normal\AppData\Roaming\GRASS6\.r.li\history\movwindow7
... and no path in conf= when running the r.li.* modules.
See also:
http://grasswiki.osgeo.org/wiki/GRASS_configuration_files_in_home_directory
You may try to use 'g.gisenv set="DEBUG=1"' to check where r.li.* is
seeking.
Once understood, we should add a note in
grass64/raster/r.li/r.li.setup/description.html
Ticket URL: <http://trac.osgeo.org/grass/ticket/2392#comment:5>
