[GRASS-dev] [GRASS GIS] #2395: Startup runs as in Cygwin when CYGWIN is set although running as native application
trac at osgeo.org
Wed Aug 20 02:01:07 PDT 2014
application
Reporter: wenzeslaus | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Startup | Version: svn-releasebranch70
Keywords: cygwin, wingrass, environmetal variables | Platform: MSWindows 8
Cpu: Unspecified |
Comment(by zarch):
Replying to [comment:3 hellik]:
> it should be something (adapted to beta3) like
[cut]
a cleaned version could be:
# Variables substituted during build process
cmd_name = "grass70"
grass_version = "7.0.0svn"
ld_library_path_var = 'PATH'
gisbase = os.environ.get('GISBASE',
"/c/OSGeo4W/apps/grass/grass-7.0.0svn")
config_projshare = os.environ.get('GRASS_PROJSHARE',
"/c/OSGeo4W/share/proj")
And I believe that variables: cmd_name and grass_version that at the
moment are hard-coded should be defined in some more clever way.
I'm not sure but I think that even the path: /c/OSGeo4W/ could/should be a
variable in case that the user change the default installation directory.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2395#comment:6>
