[GRASS-dev] [GRASS GIS] #2395: Startup runs as in Cygwin when CYGWIN is set although running as native application
trac at osgeo.org
Wed Aug 20 02:15:26 PDT 2014
application
Reporter: wenzeslaus | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Startup | Version: svn-releasebranch70
Keywords: cygwin, wingrass, environmetal variables | Platform: MSWindows 8
Cpu: Unspecified |
Comment(by hellik):
Replying to [comment:6 zarch]:
> I'm not sure but I think that even the path: /c/OSGeo4W/ could/should be
a variable in case that the user change the default installation
directory.
the path (is?)/should be adapted by the osgeo4w-installation-script.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2395#comment:7>
