[GRASS-dev] [GRASS GIS] #2395: Startup runs as in Cygwin when CYGWIN is set although running as native application
trac at osgeo.org
Wed Aug 20 07:47:11 PDT 2014
application
Reporter: wenzeslaus | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Startup | Version: svn-releasebranch70
Keywords: cygwin, wingrass, environmetal variables | Platform: MSWindows 8
Cpu: Unspecified |
Comment(by wenzeslaus):
Replying to [comment:1 glynn]:
> Replying to [ticket:2395 wenzeslaus]:
> > 1) Do you need CYGWIN variable in you environment for some reason?
> FWIW, the CYGWIN variable isn't even set in my Cygwin64 environment, so
checking it may lead to false negatives as well as false positives.
> > 2) For GRASS GIS, is there some better way of getting to know if it is
running as Cygwin application?
> For a Python script, sys.platform will tell you if you're running a
Cygwin version of Python.
So, I will change this accoring to [http://lists.osgeo.org/pipermail
/grass-user/2014-August/070728.html GRASS-user Grass-7.0 beta3 fails to
launch]:
if sys.platform == 'cygwin':
I'm just not sure from the documentation if "equals", "startswith", or
"in" is more appropriate.
> Another option would be to check for the presence of the variable SHELL
in the environment. If it doesn't exist, GRASS is probably being launched
from a desktop icon or start menu entry, in which case the GUI should be
started directly. If SHELL is set, GRASS should spawn a session using that
shell, in the current console.
According to comment and the source code I think that `SHELL` variable
might be somehow wrong sometimes.
* source:grass/trunk/lib/init/grass.py#L906
> Ideally, we shouldn't be trying to distinguish Cygwin from other Unix
platforms except where this turns out to be strictly necessary.
Yes, we would be defeating the purpose of Unix and Cygwin then but I guess
this is the exception.
> > 3) Is this Cygwin part even needed? We are not relying on Cygwin in
GRASS GIS 7 anymore and we don't plan to do so, as far as I know. So, a
possile solution is just removing this Cygwin-related code.
> This isn't version-specific. For a long time, we have offered GRASS for
both (native) Windows and Cygwin. Some Windows users (e.g. those who
already use Cygwin for other reasons) may prefer the Cygwin version.
OK, if we still support Cygwin and it is still possible to install GRASS
GIS like this we need to keep the code there.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2395#comment:9>
