[GRASS-dev] updates needed on wingrass webpage?
Markus Neteler
neteler at osgeo.org
Wed Aug 20 08:29:44 PDT 2014
On Wed, Aug 20, 2014 at 4:22 PM, Vaclav Petras <wenzeslaus at gmail.com> wrote:
> The problem is that what is in installer does not fit with what is online,
> so it is hard to create instructions for multiple platforms since the name
> of location will be different if you download file using installer on MS
> Windows and if you download manually on any platform.
> And then we are also referring to this sample location in manuals in some
> way. I recently stepped into this issue too when writing documentation for
> testing framework.
Right. So we should develop a naming scheme here which permits to have
sample locations of different datasets for different GRASS versions.
Maybe we use the one we have for NC or maybe there are better
suggestions. The one for Spearfish is confusing.
Markus
