[GRASS-dev] GRASS7relbr/GRASS7trunk: GUI error message: ascii' codec can't decode byte 0xc3 in position 11: ordinal not in range(128)
Anna Petrášová
kratochanna at gmail.com
Wed Aug 20 08:33:39 PDT 2014
On Wed, Aug 20, 2014 at 8:00 AM, Helmut Kudrnovsky <hellik at web.de> wrote:
> Helmut Kudrnovsky wrote
> > any command, where input (vector/raster-modules: e.g. r.contour, v.drape,
> > etc.) _and_ output is needed in one GUI tab, gives an error message, when
> > input is selected:
> > e.g. r.contour
> > Traceback (most recent call last):
> > File "C:\OSGeo4W\apps\grass\grass-7.0.0svn\gui\wxpython\gu
> > i_core\forms.py", line 2146, in OnSetValue
> > self.OnUpdateValues(event)
> > i_core\forms.py", line 615, in updateValuesHook
> > self.SetStatusText('
> > '.join(self.notebookpanel.createCmd(ignoreErrors = True)))
> > UnicodeDecodeError
> > 'ascii' codec can't decode byte 0xc3 in position 11: ordinal
> > not in range(128)
> > some encoding issues?
> AFAICT the error message is not in 7beta3
I fixed that hopefully in r61704 in trunk. It was caused by wrong handling
of translatable string.
Anna
> best regards
> Helmut
> http://osgeo-org.1560.x6.nabble.com/GRASS7relbr-GRASS7trunk-GUI-error-message-ascii-codec-can-t-decode-byte-0xc3-in-position-11-ordinal--tp5157311p5157313.html
> Sent from the Grass - Dev mailing list archive at Nabble.com.
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140820/e4f4b0c1/attachment-0001.html>
