[GRASS-dev] GRASS7relbr/GRASS7trunk: GUI error message: ascii' codec can't decode byte 0xc3 in position 11: ordinal not in range(128)
Helmut Kudrnovsky hellik at web.de
Wed Aug 20 05:00:51 PDT 2014
Helmut Kudrnovsky wrote
> any command, where input (vector/raster-modules: e.g. r.contour, v.drape,
> etc.) _and_ output is needed in one GUI tab, gives an error message, when
> input is selected:
> e.g. r.contour
> Traceback (most recent call last):
>   File "C:\OSGeo4W\apps\grass\grass-7.0.0svn\gui\wxpython\gu
> i_core\forms.py", line 2146, in OnSetValue
> self.OnUpdateValues(event)
> i_core\forms.py", line 615, in updateValuesHook
> self.SetStatusText('
> '.join(self.notebookpanel.createCmd(ignoreErrors = True)))
> UnicodeDecodeError
> 'ascii' codec can't decode byte 0xc3 in position 11: ordinal
> not in range(128)
> some encoding issues?
AFAICT the error message is not in 7beta3
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/GRASS7relbr-GRASS7trunk-GUI-error-message-ascii-codec-can-t-decode-byte-0xc3-in-position-11-ordinal--tp5157311p5157313.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
