[GRASS-dev] Some minor TGIS issues in GRASS 7.1
Blumentrath, Stefan
Stefan.Blumentrath at nina.no
Fri Aug 22 04:22:13 PDT 2014
One additional thing:
t.rast.mapcalc2 does not seem to read STDS from other mapsets. I get a parse error regardless if I use full map names with mapset specified (then expression parsing seems to break at the "at") or if I add the other mapset to the current search path and do not specify the mapset in the expression (in the latter case the modul complains that the map cannot be found in the current mapset)?
Anyone who can confirm?
Cheers
Stefan
