[GRASS-dev] v.perturb
Moritz Lennert
mlennert at club.worldonline.be
Thu Aug 28 07:37:59 PDT 2014
On 28/08/14 16:02, Alessandro Samuel Rosa wrote:
> I will follow your suggestion as far such functionality is not
> implemented in v.perturb.
Attached a very crude and untested attempt at a region check. If you can
compile GRASS, you could try to see if it works. It should probably be
made conditional on a flag as most people would not expect a vector
module to take region settings into account.
You can also file an enhancement request in the GRASS Trac.
Moritz
Type: text/x-patch
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140828/5e317ede/attachment.bin>
