[GRASS-dev] small interface inconsistency in r.to.vect in GRASS	7
    Anna Petrášová
    kratochanna at gmail.com
    Tue Dec  2 05:29:20 PST 2014
On Tue, Dec 2, 2014 at 12:01 AM, Michael Barton <Michael.Barton at asu.edu>
wrote:
>  On Dec 1, 2014, at 9:31 PM, Anna Petrášová <kratochanna at gmail.com> wrote:
>  On Mon, Dec 1, 2014 at 6:21 PM, Michael Barton <Michael.Barton at asu.edu>
> wrote:
>> In r.to.vect, this argument ONLY refers to the output vector feature.
>> There are not any different feature types for the 2D raster maps that are
>> input to this module. I assume that while the nature of the raster map
>> affects the vector feature type to some extent, this argument can force it
>> to output a particular feature type when there is the potential for
>> multiple feature type output.
>> I suppose simply “feature type” is OK. But it is the output vector map
>> that is being referred to in any case and “input” feature type is
>> misleading IMHO.
>  Probably revert http://trac.osgeo.org/grass/changeset/59324? Or create
> separate options G_OPT_V_TYPE_INPUT, G_OPT_V_TYPE_OUTPUT?
>  But the input is always a raster. So there is no reason for an option
> G_OPT_V_TYPE_INPUT
>  The output is always a vector, which CAN have different feature types,
> so there is a reason for G_OPT_V_TYPE_OUTPUT.
I was talking about introducing new standard options G_OPT_V_TYPE_INPUT,
G_OPT_V_TYPE_OUTPUT which would differ only in description (Input feature
type/Output feature type). r.to.vect would then use G_OPT_V_TYPE_OUTPUT,
v.to.rast would use  G_OPT_V_TYPE_INPUT. Or we just stay with G_OPT_V_TYPE
and redefine description.
>  Michael
>  Anna
>> Michael
>> ____________________
>> C. Michael Barton
>> Director, Center for Social Dynamics & Complexity
>> Professor of Anthropology, School of Human Evolution & Social Change
>> Head, Graduate Faculty in Complex Adaptive Systems Science
>> Arizona State University
>> voice:  480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
>> fax: 480-965-7671 (SHESC),  480-727-0709 (CSDC)
>> www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
>>  On Dec 1, 2014, at 4:13 PM, Markus Neteler <neteler at osgeo.org> wrote:
>> > On Sat, Nov 29, 2014 at 6:20 PM, Michael Barton <Michael.Barton at asu.edu>
>> wrote:
>> >> I just ran into this last night.
>> >> The description for the “type” argument for r.to.vect calls it “Input
>> >> feature type”, but actually it should be “Output feature type”.
>> > I'm not sure. The raster input defines also the output to some extent.
>> > In G6 it was simply called "Feature type", perhaps we should restore
>> > that description?
>> > Markus
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20141202/07b91402/attachment.html>
