[GRASS-dev] [GRASS GIS] #2503: wxdigit: wrong undo & redo
trac at osgeo.org
Wed Dec 3 01:07:36 PST 2014
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: wxGUI | Version: svn-trunk
Keywords: digitizer | Platform: Unspecified
Cpu: Unspecified |
Comment(by mlennert):
Replying to [comment:5 mmetz]:
> Replying to [comment:4 mlennert]:
> > Replying to [comment:3 mmetz]:
> > > Replying to [comment:2 mlennert]:
> > > > There still is some confusion when one goes back one or two steps,
then digitizes something else.
> > > The question is what should happen with the available redo steps if
digitize something new after some undo steps. Eliminate the redo steps or
insert the new changeset before the first redo step? This is handled by
the wx digitizer, not the vector lib.
> > I've tried three different programs (LibreOffice Writer, Inkscape and
GIMP) and all discard these redo steps,i.e. when you do A, then B, then
undo B, then do C, you cannot find B again.
> > This seems to be the most intuitive behaviour to me.
> OK.
> > > > When you then undo and redo again, the stack seems to be mixed
between the different paths, sometimes leading to objects left on screen
even when going all the way back to the last possible undo.
> > > It seems that a new changeset is appended after the last redo step
if available, leading to a mix-up.
> > Yes.
> Fixed in trunk r63341, please test.
Much better !
There is still one issue I've come upon: when features are automatically
modified from the form they are digitized in because of overlaps, the
second original feature causing the overlap seems to be erased from the
undo stack, meaning that it remains, even if you undo all the way to
origin or if you close without saving.
To reproduce, digitize a line and then a second line that crosses that
line. The lines are correctly split at the intersection. If you then undo
the second line remains in its original (unsplit) form. The same is true
for two overlapping polygons or a line crossing a polygon.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2503#comment:6>
