[GRASS-dev] [GRASS GIS] #2409: last call for options keys consolidation
trac at osgeo.org
Wed Dec 3 01:19:39 PST 2014
Reporter: martinl | Owner: grass-dev@…
Type: task | Status: new
Priority: blocker | Milestone: 7.0.0
Component: Default | Version: unspecified
Keywords: standardized options | Platform: Unspecified
Cpu: Unspecified |
Comment(by huhabla):
I full agree with Vaclav.
However, the modification of GRASS was already performed, regardless the
fact that we still discuss the renaming of rast, rast3d and vect options.
This, as i already stated before, completely broke the temporal framework.
It is not only a matter of renaming option names, the whole internal
temporal data type system and handling of different map types was broken
because of this. What to do now with temporal module names? Must t.rast.*
modules be renamed into t.raster.*? Or t.rast3d.* modules into
t.3draster.*?
Someone tried to fix the framework by simply renaming rast3d into
3draster, but this did not solved the problem. The framework was still
broken. Why was the testsuite not used to check these changes? Why do we
have the test-framework anyway?
Just a tiny hint: renaming the option "n" from v.random into "npoints"
broke plenty of temporal vector module tests, since they are using PyGRASS
to call v.random and PyGRASS can't handle abbreviations.
I needed 5 hours to fix the temporal framework and i am pretty sure that i
did not catch all issues that were introduced with the renaming.
Putting GRASS in such broken a state without using the testuite to write
and use tests or at least to verify the changes with existing tests is
IMHO irresponsible. Especially if we plan to make a beta release.
I am sorry for my harsh words, but i had to invest 5h for no good reason
to keep on with my regular work.
Replying to [comment:80 wenzeslaus]:
> Replying to [comment:79 glynn]:
> > Replying to [comment:77 annakrat]:
> > > Replying to [comment:76 cmbarton]:
> > > > Could it cause a problem somewhere down the line to have this term
beginning with a number--e.g. If it is used to name a temp file or
something?
> > > As I already said, it causes problems for Python because keyword
parameter can't start with number. This is solvable by adding underscore
and some special handling of this case, which is partially there already.
It violates pep8.
> > PEP8 is a style guide. There is no inherent reason why an argument
name cannot start with an underscore. And we're not even talking about
explicit arguments; such arguments will only ever be obtained via the
**kwargs mechanism.
> The problem may come once you want to use parameter as an variable or
member variable. In later case underscore would means private which is
technique not limited to Python. I'm also afraid that this can hit us or
somebody else in some other language or system. Almost nothing allows
numbers at the beginning of identifiers. I also think that for 3D raster
it is much more probable that you hit this issue. For example, how should
I name variable in my script which holds 3D raster map name or its
maximum? `_3draster_name`? `_3draster_max`? I can of course name my
variables whatever I want but wouldn't we stick to `rast3d` or `raster3d`
in the GRASS source code anyway?
> > In fact, I think that this is why I chose to use a leading underscore
rather than a trailing underscore.
> > Still, I'd rather avoid having option names start with a digit. But
unless we relax the ambiguity check, it wouldn't outweigh my preference to
avoid using an option name which has a very common option name (rast or
raster) as a prefix.
> I'm glad you are saying that. I think it is really important to state
the priorities and motivations. If we just want backwards compatibility,
then some special check in the parser can handle old short option names.
And if we value the most backwards compatibility and short options, we
probably should not not shorten at all in these special cases (type
names).
> Perhaps it is useful to ask why we want short options. It is for manual
typing? Well then we perhaps should use techniques used elsewhere. And we
are actually partially doing it. There is IDE-like auto-complete in GUI,
Python dir completed is implemented for PyGRASS module interface and of
course Linux command line auto-completes module names. So why not to take
it further and auto-complete also parameters and perhaps other things by
implementing auto-complete for shell?
> Classic unix-like command line is anyway the only place where short
options really matter if you consider the things above and also that you
should not use shortened option names in scripts because it is not
readable (that's why we are unabbreviating them, right?).
> Perhaps we don't have to unabbreviate everything. It seems to me that
there is no will to unabbreviate options for `g.region` or module names
containing rast, vect or rast3d. I'm for explicit long descriptive option
names but if it creates more issues then it solves (`3draster`) and if
everybody would be using the shortened version all the time anyway
(`rast`, ...), I prefer not to change them.
> If we want short options for whatever reason, let's standardize them,
rather than standardize the long options and provide ways how to avoid the
standard.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2409#comment:85>
