[GRASS-dev] [GRASS GIS] #2503: wxdigit: wrong undo & redo
trac at osgeo.org
Wed Dec 3 02:04:24 PST 2014
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: wxGUI | Version: svn-trunk
Keywords: digitizer | Platform: Unspecified
Cpu: Unspecified |
Comment(by mmetz):
Replying to [comment:6 mlennert]:
> There is still one issue I've come upon: when features are automatically
modified from the form they are digitized in because of overlaps, the
second original feature causing the overlap seems to be erased from the
undo stack, meaning that it remains, even if you undo all the way to
origin or if you close without saving.
> To reproduce, digitize a line and then a second line that crosses that
line. The lines are correctly split at the intersection. If you then undo
the second line remains in its original (unsplit) form. The same is true
for two overlapping polygons or a line crossing a polygon.
The list of updated lines as returned by the vector lib was incomplete.
Fixed in r63349,50 (trunk, relbr70), please test.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2503#comment:7>
