[GRASS-dev] [GRASS GIS] #2506: g.rename fails to rename map when there is already map of the same name in PERMENENT
trac at osgeo.org
Wed Dec 3 08:22:17 PST 2014
PERMENENT
Reporter: annakrat | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Default | Version: svn-trunk
Keywords: g.rename | Platform: Unspecified
Cpu: Unspecified |
In a mapset (different than PERMANENT) I run:
g.rename raster=mymap,elevation
WARNING: <elevation> already exists in mapset <PERMANENT>
It doesn't rename it. When I use overwrite, it works. Still it seems it's
a bug.
Also when I add there my current mapset, it fails, and I thought we
decided that current mapset should be supported when specifying output map
names.
g.rename raster=mymap,elevation at mycurrentmapset
WARNING: Illegal filename <elevation at mycurrentmapset>. Character <@> not
allowed.
WARNING: <elevation at mycurrentmapset> is an illegal file name
Ticket URL: <http://trac.osgeo.org/grass/ticket/2506>
