[GRASS-dev] [GRASS GIS] #2510: v.db.addcolumn, bad parser syntax in script causes error, cascades to other modules
trac at osgeo.org
Wed Dec 10 11:30:27 PST 2014
modules
Reporter: isaacullah | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 7.0.0
Component: Vector | Version: svn-releasebranch70
Keywords: parser, syntax, error, script | Platform: Linux
Cpu: x86-64 |
Hi all,
In latest version of 7 from GRASS stable Ubuntu PPA archive,
v.db.addcolumn is broken because of a change to the parser code in the
script. The error is:
ERROR: Sorry, <map> is not a valid parameter
ERROR: Required parameter <output> not set:
(Name for output vector map)
But this is because the only options are "output", and "map" and "layer"
don't show up. Looking at the script, I see that the relevant parser code
in the header is this:
#%module
#% description: Adds one or more columns to the attribute table connected
to a given vector map.
#% keywords: vector
#% keywords: attribute table
#% keywords: database
#%end
#%option G_OPT_V_MAP
#%end
#%option G_OPT_V_FIELD
#% label: Layer number where to add column(s)
#%end
#%option
#% key: columns
#% type: string
#% label: Name and type of the new column(s) ('name type [,name type,
#% description: Data types depend on database backend, but all support
VARCHAR(), INT, DOUBLE PRECISION and DATE
#% required: yes
#%end
It's obvious that it's the "G_OPT_V_MAP" and "G_OPT_V_FIELD" that are
causing the error. I've not ever used that syntax in my own scripts (I
wasn't aware that one *cold* do that, actually), but th error is fixed by
changing to the "normal" parser syntax:
#%module
#% keywords: vector
#%end
#%option
#% key: map
#% type: string
#% gisprompt: old,vector,vector
#% label: Name of map to add columns to the database
#% required: yes
#%end
#%option
#% key: layer
#% type: integer
#% answer: 1
#% required: yes
#%end
#%option
#% key: columns
#% type: string
#% required: yes
#%end
Not sure if the v.db.addcolumn code was always like that, and the error is
caused by some other change, or if this is due to a recent change to the
script itself, but it seems like an easy fix. This is a serious bug
because it breaks a lot of the other vector tools.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2510>
