[GRASS-dev] [GRASS GIS] #2510: v.db.addcolumn, bad parser syntax in script causes error, cascades to other modules
trac at osgeo.org
Wed Dec 10 12:53:31 PST 2014
modules
Reporter: isaacullah | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 7.0.0
Component: Vector | Version: svn-releasebranch70
Keywords: parser, v.db.addcolumn | Platform: Linux
Cpu: x86-64 |
Changes (by neteler):
* keywords: parser, syntax, error, script => parser, v.db.addcolumn
Comment:
Replying to [ticket:2510 isaacullah]:
> Hi all,
> In latest version of 7 from GRASS stable Ubuntu PPA archive,
v.db.addcolumn is broken because of a change to the parser code in the
script. The error is:
> ERROR: Sorry, <map> is not a valid parameter
> ERROR: Required parameter <output> not set:
> (Name for output vector map)
Is it really the latest you are using there? We have made a major code
cleanup, perhaps
the package was created in the "transition days"?
I just tried, works fine with the really current version:
GRASS 7.0.0svn (nc_spm_08_grass7):~ > v.db.addcolumn random column="el102
double precision"
GRASS 7.0.0svn (nc_spm_08_grass7):~ > g.version -g
version=7.0.0svn
date=2014
revision=63285M
build_date=2014-12-03
build_platform=x86_64-unknown-linux-gnu
Ticket URL: <http://trac.osgeo.org/grass/ticket/2510#comment:1>
