[GRASS-dev] GRASS 7 - Ubuntu package build problem on Launchpad
Markus Neteler
neteler at osgeo.org
Thu Dec 11 06:02:37 PST 2014
On Thu, Dec 11, 2014 at 2:58 PM, Ivan Mincik <ivan.mincik at gmail.com> wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> On 11.12.2014 14:49, Markus Neteler wrote:
>> On Thu, Dec 11, 2014 at 10:23 AM, Ivan Mincik
>> <ivan.mincik at gmail.com> wrote: ...
>>> No, what you see on that page is actually build in my repository
>>> (GIS packages (development) is mine).
>>> You have to do it also for yours. Click on 'Request build(s)' and
>>> build it for your stable repo.
>> Ok, I finally found the button:
>> "Request builds for grass70-release Distribution series: [x] Vivid
>> [x] Utopic [x] Trusty [x] Precise [x] Lucid "
>> (Vivid and Lucid were not enabled by default, I would enable)
> I am not sure with Lucid. Maybe there are no suitable dependent
> packages in UbuntuGIS.
OK, so I have taken that out. But...
"There were also some errors:
You must specify the archive to build into."
Only, there is no archive to select from (selection list is empty).
Any hints?
Markus
> Ivan Minčík
> ivan.mincik at gmail.com GPG: 0x79529A1E
> http://imincik.github.io/0x79529A1E.key
> ivan.mincik at gista.sk GPG: 0xD714B02C
> http://imincik.github.io/0xD714B02C.key
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1
> iQEcBAEBAgAGBQJUiaMAAAoJEPfdLsR5UpoePnIIAI/n4vbs4R9hiQnydIuDZTrd
> A0Pomlwt1wUoX8LgiNMcnorUqBY1EjlIgVJyau17nFiizca8PCMwZtCY2YNB1hwN
> ZEVg4dG29dG/z659BJpMs/cqvWo8fcS2DbzOTMmMbdkvz3vv5jcBlCltmpQI4bx2
> LbrKdhJuZyXYB7Rif6NT3nJfDrg+vIpswrgfcMEY/gGPKfTeYVEYpZEuOp4bV0yw
> KX2rphgQslR9llboiz/+x+JpBhWJEdXQKBjEcImeKDvb2M8SbU+yf15PUmdVj6UI
> 7ixN3SoSiRw0o6YWsHm4lqOoubuAJJV+Osa7z4zeDGPtFoEn89GpJFvfrzb3c4w=
> =JkW5
> -----END PGP SIGNATURE-----
