[GRASS-dev] [GRASS GIS] #2509: d.mon output overwrite
GRASS GIS trac at osgeo.org
Fri Dec 12 10:53:46 PST 2014
 Reporter:  martinl      |       Owner:  martinl
     Type:  defect       |      Status:  assigned
 Priority:  normal       |   Milestone:  7.0.0
Component:  Display      |     Version:  unspecified
 Keywords:  d.mon        |    Platform:  Unspecified
      Cpu:  Unspecified  |
Comment(by neteler):
 Replying to [comment:11 glynn]:
 > Replying to [comment:10 martinl]:
 > > I really don't see the current behaviour of display commands in trunk
 as reasonable.
 > The current behaviour is exactly the same as the old behaviour before
 someone decided to try to reincarnate the "monitor" concept from prior
 versions and introduced a bug in the process.
 This happens.
 However, the monitor concept is essential also for GRASS 7. At least for
 power users who stick to the command line. It is sad enough that the fast
 x0 monitor from GRASS 6 hasn't been replaced with a fast alternative.
 The current behaviour of d.* to silently write into a PNG file is
 unhelpful. At least a message about the newly generated/modified file
 should be generated, otherwise the d.* behaviour remains obscure.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2509#comment:12>
