[GRASS-dev] [GRASS GIS] #2509: d.mon output overwrite
trac at osgeo.org
Fri Dec 12 11:11:34 PST 2014
Reporter: martinl | Owner: martinl
Type: defect | Status: assigned
Priority: normal | Milestone: 7.0.0
Component: Display | Version: unspecified
Keywords: d.mon | Platform: Unspecified
Cpu: Unspecified |
Comment(by martinl):
Replying to [comment:11 glynn]:
> It's bogus because there's simply no reason for that check to be there.
Everything worked fine before someone mistakenly added it, and works fine
now that it has been removed. The only consequence of that check was to
generate an error for entirely valid usage.
well, it worked fine also before you reverted it. The reason of this
condition was simple. Not to generate output by the default display driver
(ie. to write map.png to the current directory) without noticing to the
user. Such behaviour is really obscure. The user should be asked to start
monitor (`d.mon`) or to specify display driver by environmental variable
(GRASS_RENDER_IMMEDIATE).
Ticket URL: <http://trac.osgeo.org/grass/ticket/2509#comment:13>
