[GRASS-dev] [GRASS GIS] #2409: last call for options keys consolidation
trac at osgeo.org
Thu Dec 18 09:02:28 PST 2014
Reporter: martinl | Owner: grass-dev@…
Type: task | Status: new
Priority: blocker | Milestone: 7.0.0
Component: Default | Version: unspecified
Keywords: standardized options | Platform: Unspecified
Cpu: Unspecified |
Comment(by hcho):
Replying to [comment:136 hcho]:
> Replying to [comment:133 glynn]:
> > Replying to [comment:131 hcho]:
> > > * modules with parameters `raster_map=` and `raster_map_2=`: `rast`
ambiguous, `rmap` for `raster_map=` and `rmap2` for `raster_map_2=`
> > > * modules with parameters `raster_map=` and `raster_map2=`: `rast`
ambiguous, `rmap` for `raster_map=` and `rmap2` for `raster_map2=`
> > > I'm not sure if I was clear enough here.
> > You're suggesting that the abbreviation must include some part of the
last word of the option name? Or that it must include the last character?
I.e. is rm= ambiguous?
> No, not the last word of the option name. You cannot skip any words
separated by an underscore. rm= is not ambiguous in this case because the
shortest option name that matches rm= is raster_map=. If one wants
raster_map2=, use rmap2=, not rm2= (no abbreviation inside a word).
I mean the shortest option name with no more following underscores. 'r'
for raster, 'm' for map, and no more underscores after 'raster_map'.
If you have `raster_map_1=` and `raster_map_2=`, `rm=` would be ambiguous
because `raster_map` is still ambiguous. If you have `raster_map=` and
`raster_map_2=`, `rm=` expands to `raster_map=` and it's not ambiguous.
> > The main problems I foresee with that are
> > * The last word (or an abbreviation of it) might match some earlier
portion of the option name, meaning that the user intended to specify
(part of) the last word but the characters were matched against an earlier
portion.
> I'm not talking about skipping words and using the last word, so this is
not the case.
> > * It's possible for a string to match the last word of multiple
options. E.g. given options raster_map and raster_2_map, rmap would match
both equally.
> rmap= would match raster_map= "only" because you cannot skip 2.
> Hope I'm clearer now.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2409#comment:137>
