[GRASS-dev] [GRASS GIS] #2403: cairo driver fails to create surface
trac at osgeo.org
Thu Dec 18 09:05:05 PST 2014
Reporter: martinl | Owner: martinl
Type: defect | Status: closed
Priority: major | Milestone: 7.0.0
Component: Display | Version: unspecified
Resolution: fixed | Keywords: cairo, resolution, surface
Platform: Linux | Cpu: x86-64
Changes (by martinl):
* status: assigned => closed
* resolution: => fixed
Comment:
Replying to [comment:9 glynn]:
> r63582 makes the cairo driver behave almost identically to the PNG
driver.
I took liberty to backport it in r63595.
> For reasons which I've been unable to determine so far, the result is
one destination pixel wider than with the PNG driver.
> Ultimately, the code should be modified to use an intermediate surface
which has the same dimensions as the destination rectangle, to avoid the
overhead of copying the (empty) borders.
Since the originally reported issue has been fixed, I took liberty to
close this ticket.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2403#comment:10>
