[GRASS-dev] GRASS 7 - Ubuntu package build problem on Launchpad
Markus Neteler
neteler at osgeo.org
Tue Dec 30 02:46:09 PST 2014
Hi all,
just tried to install GRASS GIS 7 on a freshly installed Ubuntu 12.4
box but it failed (see below). I thought the issue had been solved in
the past. Is my install sequence wrong which I took from the GRASS web
site?
ubuntu at gislab-nuc:~$ sudo add-apt-repository ppa:grass/grass-stable;
sudo apt-get update; sudo apt-get install grass70-core grass70-gui
grass70-doc
[sudo] password for ubuntu:
You are about to add the following PPA to your system:
GRASS Packages for the development release branch.
This is currently Version 7.0
NOTE:
These packages are NOT the OFFICIAL stable and tested packages by
UBUNTU & DEBIAN GIS team.
UBUNTU packages are found here:
https://launchpad.net/ubuntu/+source/grass
and UBUNTU GIS packages here:
* https://launchpad.net/~ubuntugis/+archive/ubuntugis-testing
* https://launchpad.net/~ubuntugis/+archive/ubuntugis-unstable
* https://launchpad.net/~ubuntugis/+archive/ppa
More info: https://launchpad.net/~grass/+archive/ubuntu/grass-stable
Press [ENTER] to continue or ctrl-c to cancel adding it
gpg: keyring `/tmp/tmp4AsXPl/secring.gpg' created
gpg: keyring `/tmp/tmp4AsXPl/pubring.gpg' created
gpg: requesting key 26D57B27 from hkp server keyserver.ubuntu.com
gpg: /tmp/tmp4AsXPl/trustdb.gpg: trustdb created
gpg: key 26D57B27: public key "Launchpad PPA for GRASS GIS" imported
gpg: Total number processed: 1
gpg: imported: 1 (RSA: 1)
OK
Hit http://it.archive.ubuntu.com precise Release.gpg
Hit http://extras.ubuntu.com precise Release.gpg
Hit http://it.archive.ubuntu.com precise-updates Release.gpg
Hit http://it.archive.ubuntu.com precise-updates/universe Translation-en
Hit http://it.archive.ubuntu.com precise-backports/main Translation-en
Hit http://it.archive.ubuntu.com precise-backports/multiverse Translation-en
Hit http://it.archive.ubuntu.com precise-backports/restricted Translation-en
Hit http://it.archive.ubuntu.com precise-backports/universe Translation-en
Fetched 23.3 kB in 4s (4,935 B/s)
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
grass70-core : Depends: libgdal1h (>= 1.8.0) but it is not installable
Depends: libgeos-c1 (>= 3.4.2) but it is not going to
be installed
Depends: libproj0 (>= 4.8.0-1) but it is not going to
be installed
Recommends: gdal-bin but it is not going to be installed
Recommends: proj-bin but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
thanks for any hints,
Markus
