[GRASS-dev] GRASS 7 - Ubuntu package build problem on Launchpad
Ivan Mincik ivan.mincik at gmail.com
Tue Dec 30 05:30:59 PST 2014
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
On 30.12.2014 11:46, Markus Neteler wrote:
> Hi all,
> just tried to install GRASS GIS 7 on a freshly installed Ubuntu
> 12.4 box but it failed (see below). I thought the issue had been
> solved in the past. Is my install sequence wrong which I took from
> the GRASS web site?
> ubuntu at gislab-nuc:~$ sudo add-apt-repository
> ppa:grass/grass-stable; sudo apt-get update; sudo apt-get install
> grass70-core grass70-gui grass70-doc [sudo] password for ubuntu:
> You are about to add the following PPA to your system: GRASS
> Packages for the development release branch. This is currently
> Version 7.0 NOTE: These packages are NOT the OFFICIAL stable and
> tested packages by UBUNTU & DEBIAN GIS team. UBUNTU packages are
> found here: https://launchpad.net/ubuntu/+source/grass and UBUNTU
> GIS packages here: *
> https://launchpad.net/~ubuntugis/+archive/ubuntugis-testing *
> https://launchpad.net/~ubuntugis/+archive/ubuntugis-unstable *
> https://launchpad.net/~ubuntugis/+archive/ppa More info:
> https://launchpad.net/~grass/+archive/ubuntu/grass-stable Press
> [ENTER] to continue or ctrl-c to cancel adding it gpg: keyring
> `/tmp/tmp4AsXPl/secring.gpg' created gpg: keyring
> `/tmp/tmp4AsXPl/pubring.gpg' created gpg: requesting key 26D57B27
> from hkp server keyserver.ubuntu.com gpg:
> /tmp/tmp4AsXPl/trustdb.gpg: trustdb created gpg: key 26D57B27:
> public key "Launchpad PPA for GRASS GIS" imported gpg: Total number
> processed: 1 gpg:               imported: 1  (RSA: 1) OK Hit
> http://it.archive.ubuntu.com precise Release.gpg Hit
> http://extras.ubuntu.com precise Release.gpg Hit
> http://it.archive.ubuntu.com precise-updates Release.gpg ... Hit
> http://it.archive.ubuntu.com precise-updates/universe
> Translation-en Hit http://it.archive.ubuntu.com
> precise-backports/main Translation-en Hit
> http://it.archive.ubuntu.com precise-backports/multiverse
> precise-backports/restricted Translation-en Hit
> http://it.archive.ubuntu.com precise-backports/universe
> Translation-en Fetched 23.3 kB in 4s (4,935 B/s) Reading package
> lists... Done Reading package lists... Done Building dependency
> tree Reading state information... Done Some packages could not be
> installed. This may mean that you have requested an impossible
> situation or if you are using the unstable distribution that some
> required packages have not yet been created or been moved out of
> Incoming. The following information may help to resolve the
> situation:
> The following packages have unmet dependencies: grass70-core :
> Depends: libgdal1h (>= 1.8.0) but it is not installable Depends:
> libgeos-c1 (>= 3.4.2) but it is not going to be installed Depends:
> libproj0 (>= 4.8.0-1) but it is not going to be installed
> Recommends: gdal-bin but it is not going to be installed
> Recommends: proj-bin but it is not going to be installed E: Unable
> to correct problems, you have held broken packages.
Hi Markus, this is a problem with dependency on Ubuntu GIS
repositories (I was writing about this earlier). You need to add also
Ubuntu GIS repositories in to your system using the same way as you
did for GRASS one.
Another problem is that GRASS builds depends on both
'ubuntugis-stable' and 'ubuntugis-unstable' which can produce strange
results.
The best way is to install GIS.lab which is providing GRASS 7 :). I
can update it to latest RC release if required.
BTW, I am just currently fine tuning GIS.lab Unit installation wiki
page [1].
1 - https://github.com/imincik/gis-lab/wiki/GIS.lab-Unit
Ivan Minčík
ivan.mincik at gmail.com  GPG: 0x79529A1E
http://imincik.github.io/0x79529A1E.key
ivan.mincik at gista.sk     GPG: 0xD714B02C
http://imincik.github.io/0xD714B02C.key
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1
iQEcBAEBAgAGBQJUoqkTAAoJEPfdLsR5UpoexrQH/0gADkQOp7ecUA8yn+wldXnj
wYZElgtNJ3P8k9/+WZnrBAhzViAxTXk1mwB/AQvMIgqR9r+nyTpkYYd44WUud85L
LnzP+e6RDGpG2lgenEaDEo7UWbCopc3/Fnf9mHs2A/si9vXF6NdmD3OSM/s4NVUs
QH38Di0ANjHQIPmRZhpIPaxTOpcCIJsTN43eo4C5PYXwLmri8xYNtMq15Ih2xLb+
4b79WwuE4br89GDiWgStbZatJOQ0fylYDMv1spoMWMkXHuwh+bGGoLRVMyn0tnmy
Tco13MOLapuYnAGpoqaomzs6e2jgmgN9kUJZCVGrE/lawmN0Zhtz/+9KNEMqH1c=
=IOkh
-----END PGP SIGNATURE-----
