[GRASS-dev] GRASS 7 - Ubuntu package build problem on Launchpad
Ivan Mincik ivan.mincik at gmail.com
Tue Dec 30 06:13:23 PST 2014
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
On 30.12.2014 15:00, Markus Neteler wrote:
> GRASS 7.0.0 (latlong):~ > Unable to get GRASS version Unable to get
> GRASS version
> GRASS 7.0.0 (latlong):~ > g.version -g version=7.0.0svn date=2014
> revision= build_date=2014-12-13 build_platform=x86_64-pc-linux-gnu
Fine, I have also seen this error. I was not sure if it is bug or some
build configuration problem, so I was not sure if I should report it.
My earlier note to packages versioning:
For Ubuntu PPA builds I strongly suggest to update build recipe with
SVN revision number instead of meaningless BZR one, which has no
relation to SVN and is confusing:
Proposed recipe:
# bzr-builder format 0.4 deb-version 7.0.0+1svn{svn-revno}
lp:grass/7.0
nest debianfiles lp:~grass/grass/grass70_release_debian debian
Ivan Minčík
ivan.mincik at gmail.com  GPG: 0x79529A1E
http://imincik.github.io/0x79529A1E.key
ivan.mincik at gista.sk     GPG: 0xD714B02C
http://imincik.github.io/0xD714B02C.key
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1
iQEcBAEBAgAGBQJUorMDAAoJEPfdLsR5UpoeX5kH/RN4rUJCe2tytSbiDQB0nRcU
vS7b2/F4a9UqvLEQkYIGu+FNNRIswv59kfN1+1tQgE2obgwiWMFPzVEb6+8Gwt1d
x45IfA4orTZLL41z4WPrlsS1UreWuUrPPvHYVP8RFmLivAQr8wSAz2xdmZQUD06f
04AIo6C8ztkUDOTi7bcblwUexkn9GILPbXc5puwSXh37gtqZaK9dMS/LB9jgbP4/
X7zo+3x2kTBvqbtdWquYBRGM5V5VAQ/ew9mZBDd2yU6EpITE/DZz9kX8WoDqoMJI
qp/hX9Ayx6ZximSnmfVhDu211irrEBLkswnLk+Ga14ca8elVvoO9mRcA/y9zFTw=
=gJic
-----END PGP SIGNATURE-----
