[GRASS-dev] GRASS 7 - Ubuntu package build problem on Launchpad
Markus Neteler
neteler at osgeo.org
Tue Dec 30 06:29:50 PST 2014
On Tue, Dec 30, 2014 at 3:13 PM, Ivan Mincik <ivan.mincik at gmail.com> wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> On 30.12.2014 15:00, Markus Neteler wrote:
>> GRASS 7.0.0 (latlong):~ > Unable to get GRASS version Unable to get
>> GRASS version
>> GRASS 7.0.0 (latlong):~ > g.version -g version=7.0.0svn date=2014
>> revision= build_date=2014-12-13 build_platform=x86_64-pc-linux-gnu
> Fine, I have also seen this error. I was not sure if it is bug or some
> build configuration problem, so I was not sure if I should report it.
It only occurs on Ubuntu and will render GRASS (partially) unusable.
> My earlier note to packages versioning:
> For Ubuntu PPA builds I strongly suggest to update build recipe with
> SVN revision number instead of meaningless BZR one, which has no
> relation to SVN and is confusing:
> Proposed recipe:
> # bzr-builder format 0.4 deb-version 7.0.0+1svn{svn-revno}
> lp:grass/7.0
> nest debianfiles lp:~grass/grass/grass70_release_debian debian
Not really being an Ubuntu user I have no opinion here.
But this is how the version is generated:
# original source code
include/Make/Platform.make.in:GRASS_VERSION_SVN = @GRASS_VERSION_SVN@
# --> configure -->
include/Make/Platform.make:GRASS_VERSION_SVN = 63869M
# g.version:
general/g.version/Makefile
EXTRA_CFLAGS = $(PROJINC) $(GEOSCFLAGS) \
-DGRASS_VERSION_SVN=\"'$(GRASS_VERSION_SVN)'\" \
general/g.version/main.c
# line 99:
fprintf(stdout, "revision=%s\n", GRASS_VERSION_SVN);
So, when running "configure" before compilation, the version number is
picked up:
In "configure" line 1281 and later, it executes
svnversion
which reports the SVN revision number. Could you please execute
"svnversion" in your GRASS 7.0.svn source code main directory?
Markus
