[GRASS-dev] [GRASS GIS] #2520: d.grid: -c and -d flags not displaying + and - marks
GRASS GIS trac at osgeo.org
Wed Dec 31 06:25:27 PST 2014
 Reporter:  richardc  |       Owner:  grass-dev@…
     Type:  defect    |      Status:  new
 Priority:  normal    |   Milestone:  7.0.0
Component:  Display   |     Version:  svn-trunk
 Keywords:  d.grid    |    Platform:  Linux
      Cpu:  x86-32    |
 The -c and -d flags which specify '+' and '-' marks instead of grid lines
 do not display. If the latter flags are unticked then the grid lines
 display fine.
 g.proj -p
 -PROJ_INFO-------------------------------------------------
 name       : Lambert Azimuthal Equal Area
 proj       : laea
 lat_0      : 13
 lon_0      : 101.5
 x_0        : 0
 y_0        : 0
 no_defs    : defined
 datum      : wgs84
 ellps      : wgs84
 towgs84    : 0.000,0.000,0.000
 -PROJ_UNITS------------------------------------------------
 unit       : meter
 units      : meters
 meters     : 1
 System Info
 GRASS version: 7.0.0svn
 GRASS SVN Revision: 63320
 Build Date: 2014-12-19
 Build Platform: i686-pc-linux-gnu
 GDAL/OGR: 1.11.1
 PROJ.4: 4.9.0
 GEOS: 3.4.2
 SQLite: 3.7.9
 Python: 2.7.3
 wxPython: 2.8.12.1
 Platform:LinuxMint-13-maya
Ticket URL: <http://trac.osgeo.org/grass/ticket/2520>
