[GRASS-dev] G70 Ubuntu: GUI menu access for i.eb.hsebal01 looks for i.eb.h_sebal01
Yann Chemin ychemin at gmail.com
Wed Dec 31 06:52:30 PST 2014
indeed Markus,
it is using an old file from:
/home/yann/.grass7/toolboxes/menudata.xml
Correcting that file makes it OK.
Deleting it makes it follow the PPA version.
Welcome page does show GRASS  version 7.
Additional things:
the rev number in the welcome page indicates (r00000)
The WxGUI window header say:
GRASS GIS ? Layer Manager
GRASS GIS ? Map Display: 1 - Location: GRASSDB at PERMANENT
On 31 December 2014 at 17:59, Markus Neteler <neteler at osgeo.org> wrote:
> On Wed, Dec 31, 2014 at 12:44 PM, Yann Chemin <ychemin at gmail.com> wrote:
> > Hi,
> > just got the Ubuntu PPA being worked out for G70.
> > it looks like there is a name issue in the Imagery menu looking for
> > i.eb.h_sebal01 instead of i.eb.hsebal01.
> Can you please search for the file? Because in SVN is all ok:
> cd grass70/gui/wxpython/
> grep i.eb.hsebal01 */*
> xml/menudata.xml:              <command>i.eb.hsebal01</command>
> xml/module_tree_menudata.xml:              <command>i.eb.hsebal01</command>
> xml/toolboxes.xml:      <module-item name="i.eb.hsebal01">
> Either the version you installed is outdated or something else happened.
> Markus
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20141231/dbdb8e7a/attachment.html>
