[GRASS-dev] [GRASS GIS] #2178: No polygon fill when using the pnv display driver
trac at osgeo.org
Mon Feb 3 03:27:17 PST 2014
Reporter: pvanbosgeo | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Display | Version: unspecified
Keywords: pngdriver | Platform: Unspecified
Cpu: Unspecified |
Comment(by pvanbosgeo):
I am running on Linux (Ubuntu 13.10). I just tried the North Carolina
sample dataset, but that works fine.
Layers from one of my mapsets copied to the North Carolina dataset (using
v.proj) display fine.
The other way around, layers from the North Carolina dataset copied to my
location/mapset (again, using v.proj) do not display correctly (missing
fill). See the attached GRASS dataset (GRASStest) with in the location
latlon, mapset PERMANENT one layer nc_state copied from the North Carolina
dataset.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2178#comment:2>
