[GRASS-dev] Compile errors in r.li
Vaclav Petras
wenzeslaus at gmail.com
Mon Feb 3 08:20:58 PST 2014
Markus, in case, you don;t know already, I'm getting compile errors,
probably after r58850 when compiling daemon.c (even after distclean):
daemon.c:358:24: error: implicit declaration of function 'G_easting_to_col'
is
invalid in C99 [-Werror,-Wimplicit-function-declaration]
m.f.f_ma.x = (int)G_easting_to_col(sa_e, &window);
daemon.c:359:24: error: implicit declaration of function
'G_northing_to_row' is
m.f.f_ma.y = (int)G_northing_to_row(sa_n, &window);
daemon.c:377:20: error: use of undeclared identifier 'raster_'; did you mean
'raster'?
if (strcmp(token, raster_) != 0)
raster
daemon.c:180:68: note: 'raster' declared here
int parseSetup(char *path, struct list *l, struct g_area *g, char *raster)
daemon.c:379:45: error: use of undeclared identifier 'raster_'; did you mean
'raster'?
%s rasterfile and not with %s "), token, raster_);
raster
(generated by clang, best viewed in monospace)
Vaclav
[r58850] https://trac.osgeo.org/grass/changeset/58850
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140203/72d1d36e/attachment.html>
