[GRASS-dev] [GRASS GIS] #2189: PyGRASS Module does not work on Windows
trac at osgeo.org
Thu Feb 6 08:10:36 PST 2014
Reporter: annakrat | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Python | Version: svn-trunk
Keywords: pygrass | Platform: MSWindows 8
Cpu: Unspecified |
Comment(by zarch):
Replying to [ticket:2189 annakrat]:
> PyGRASS Module class is not working on Windows. It can't find the
command:
> import grass.pygrass.modules as pymod
> region = pymod.Module("g.region")
> GrassError: 'Error running: `g.region --interface-description`.'
> If I enter the entire path of the command, it works:
[[BR]]
May be it is only a PATH problem? are you able to run the command from the
terminal?, I'm just using:
(http://trac.osgeo.org/grass/browser/grass/trunk/lib/python/pygrass/modules/interface/module.py#L243)
# call the command with --interface-description
get_cmd_xml = subprocess.Popen([cmd, "--interface-description"],
stdout=subprocess.PIPE)
[[BR]]
So from my understanding also:
core.run_command("g.region", "p")
Should not find the command. Someone has an idea why this is happening?
Both are using the same python class, and both avoid to set any special
environmental variable...
[[BR]]
> Maybe PyGRASS could be a separate component in trac?
For me it's fine.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2189#comment:1>
