[GRASS-dev] [GRASS GIS] #2189: PyGRASS Module does not work on Windows
GRASS GIS trac at osgeo.org
Thu Feb 6 08:56:15 PST 2014
 Reporter:  annakrat     |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  normal       |   Milestone:  7.0.0
Component:  Python       |     Version:  svn-trunk
 Keywords:  pygrass      |    Platform:  MSWindows 8
      Cpu:  Unspecified  |
Comment(by annakrat):
 Replying to [comment:1 zarch]:
 > Replying to [ticket:2189 annakrat]:
 > > PyGRASS Module class is not working on Windows. It can't find the
 command:
 > > import grass.pygrass.modules as pymod
 > > region = pymod.Module("g.region")
 > > GrassError: 'Error running: `g.region --interface-description`.'
 > > If I enter the entire path of the command, it works:
 > [[BR]]
 > May be it is only a PATH problem? are you able to run the command from
 the terminal?, I'm just using:
 (http://trac.osgeo.org/grass/browser/grass/trunk/lib/python/pygrass/modules/interface/module.py#L243)
 > # call the command with --interface-description
 > get_cmd_xml = subprocess.Popen([cmd, "--interface-description"],
 >                                stdout=subprocess.PIPE)
 > [[BR]]
 > So from my understanding also:
 > core.run_command("g.region", "p")
 > Should not find the command. Someone has an idea why this is happening?
 > Both are using the same python class, and both avoid to set any special
 environmental variable...
 run_command works. The difference is passing shell=True in Popen
 ([http://trac.osgeo.org/grass/browser/grass/trunk/lib/python/script/core.py#L51
 as here]) and adding this helps. Python documentation warns against using
 this but we are using it anyway in script.py. I added it in r58902. I
 haven't checked if there are other places in pygrass where it is needed.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2189#comment:2>
