[GRASS-dev] [GRASS GIS] #2189: PyGRASS Module does not work on Windows
trac at osgeo.org
Thu Feb 6 10:25:48 PST 2014
Reporter: annakrat | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Python | Version: svn-trunk
Keywords: pygrass | Platform: MSWindows 8
Cpu: Unspecified |
Comment(by annakrat):
Replying to [comment:3 zarch]:
> Replying to [comment:2 annakrat]:
> > > Should not find the command. Someone has an idea why this is
happening?
> > > Both are using the same python class, and both avoid to set any
special
> > > environmental variable...
> > run_command works. The difference is passing shell=True in Popen
> Thanks, I didn't notice that we were using a modify version of Popen!
> > I added it in r58902. I haven't checked if there are other places
> > in pygrass where it is needed.
> May be I should just use the grass.script.core.Popen class instead. I
would like to reduce duplicated code, especially these tricky parts that
are platform dependent, do you mind If I revert the commit r58902, and
apply the attached changes?
Sure, that's probably a good idea.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2189#comment:4>
