[GRASS-dev] [GRASS GIS] #2189: PyGRASS Module does not work on Windows
trac at osgeo.org
Fri Feb 7 04:08:46 PST 2014
Reporter: annakrat | Owner: grass-dev@…
Type: defect | Status: closed
Priority: normal | Milestone: 7.0.0
Component: Python | Version: svn-trunk
Resolution: fixed | Keywords: pygrass
Platform: MSWindows 8 | Cpu: Unspecified
Changes (by zarch):
* status: new => closed
* resolution: => fixed
Comment:
Replying to [comment:4 annakrat]:
> Replying to [comment:3 zarch]:
> > May be I should just use the grass.script.core.Popen
> > class instead. I would like to reduce duplicated code,
> > especially these tricky parts that are platform
> > dependent, do you mind If I revert the commit r58902,
> > and apply the attached changes?
> Sure, that's probably a good idea.
[[BR]]
ok, done in r58932. Anyway thank you for your help, you've found the
solution of the problem! :-)
I've tested on Win7 and it seems to work properly to me, so I'm closing
this ticket as fixed.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2189#comment:5>
