[GRASS-dev] Proposal for GSoC idea on INSPIRE
Vaclav Petras wenzeslaus at gmail.com
Fri Feb 7 09:49:30 PST 2014
http://trac.osgeo.org/grass/wiki/GSoC/2014#MetadataforGRASSGISmapsanddatasets
Idea is now at Trac, discussion should continue here but the results of
discussion should go there.
Vaclav
On Thu, Jan 30, 2014 at 4:28 AM, Margherita Di Leo <
dileomargherita at gmail.com> wrote:
> Hi,
> On Tue, Jan 28, 2014 at 5:30 PM, Vaclav Petras <wenzeslaus at gmail.com>wrote:
>> On Tue, Jan 28, 2014 at 11:12 AM, Moritz Lennert <
>> mlennert at club.worldonline.be> wrote:
>>> On 28/01/14 16:00, Margherita Di Leo wrote:
>>>> Hi All,
>>>> I'd like to bring a proposal for the forthcoming GSoC, that is the
>>>> support for INSPIRE. This proposal is twofold, one regarding the
>>>> metadata support, the other regarding the support for the data
>>>> transformation to meet the inspire schema. I would like to know your
>>>> opinion before drafting the idea into the trac. I'm willing to mentor
>>>> for the INSPIRE POV, and since I'm working at JRC I have the opportunity
>>>> to take advantage of a direct contact with the very people who are
>>>> developing the Directive. Martin Landa kindly made himself available to
>>>> co-mentor from the GRASS POV.
>>> +1, but I think we should aim for generic metadata handling and then
>>> allow the use of specific schemas such as INSPIRE.
>>> INSPIRE is using some more general ISO standards, isn't it?
> Correct: it is build on ISO 19100 series of International Standards. See
> [1].
> I fully agree that the general aim should be a unified system to handle
> metadata (as Yann said, interchangable and exportable into online systems).
> As I see it, the editor should remain general, to meet the users needs.
> See for example Geonetwork, it's possible to add or remove fields without
> restriction.
> The INSPIRE schema is a plus for the user, meaning that there will be
> specific hints to guide the user, i.e. direct links with the parts of the
> regulation involved in the compilation of each field of the metadata (see
> for example [2]), the possibility to validate the metadata calling the API
> of the INSPIRE validator [3], etc.
>> QGIS metatools is a nice example of such a generic tool allowing for
>>> specification of different schemas and for different outputs through the
>>> use of XSLT conversion.
>>> QGIS compatibility would be appreciated by a lot of users and it might
>> even show the way to go.
> I agree.
>> Some other thing to consider is how this metadata support would interact
>> with existing r.support, r.timestamp etc. I remember that Yann and NikosA
>> was talking about this in Genova in 2013.
> If the GSoC idea will be accepted, I'd appreciate their contribution to
> the discussion.
> [1]
> http://geostandards.geonovum.nl/index.php/6.4.6_ISO_19100_series_of_International_Standards
> [2] http://inspire-geoportal.ec.europa.eu/editor/
> [3] http://inspire-geoportal.ec.europa.eu/validator2/
> Best regards,
> Dr. Margherita DI LEO
> Scientific / technical project officer
> European Commission - DG JRC
> Institute for Environment and Sustainability (IES)
> Via Fermi, 2749
> I-21027 Ispra (VA) - Italy - TP 261
> Tel. +39 0332 78 3600
> margherita.di-leo at jrc.ec.europa.eu
> Disclaimer: The views expressed are purely those of the writer and may not
> in any circumstance be regarded as stating an official position of the
> European Commission.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140207/c1f2736d/attachment-0001.html>
