[GRASS-dev] [GRASS GIS] #2024: r.li.setup generates incomplete r.li conf file
GRASS GIS trac at osgeo.org
Fri Feb 7 11:07:50 PST 2014
 Reporter:  matmar      |       Owner:  rashadkm
     Type:  defect      |      Status:  assigned
 Priority:  normal      |   Milestone:  6.4.4
Component:  Raster      |     Version:  svn-releasebranch64
 Keywords:  r.li.setup  |    Platform:  Linux
      Cpu:  x86-64      |
Comment(by rashadkm):
 I am not able to reproduce this bug
 export WORKERS=1
 r.li.edgedensity map=geology conf=cf1 output=edege_out
 cf1 contents:
 SAMPLINGFRAME 0|0|1|1
 SAMPLEAREA -1|-1|0.03571428571428571|0.02631578947368421
 MOVINGWINDOW
 svn revision : 58937
 devbr6
 geology map from spearfish60
 moving window configuration
 Replying to [comment:27 hamish]:
 > with @PERMANENT issues fixed/avoided in devbr6, and testing a moving
 window sample with r.li.edgedensity and WORKERS=1, I'm now getting as far
 as a broken pipe error:
 > *** glibc detected *** r.li.edgedensity: free(): invalid next size
 (normal): 0x000000000265e980 ***
 > (gdb) bt
 > #0  0x00007ffff702a8d0 in __write_nocancel () at ../sysdeps/unix
 /syscall-template.S:82
 > #1  0x00007ffff755061d in send (pipe=5, m=0x7fffffffa970) at ipc.c:31
 > #2  0x00007ffff754e05b in calculateIndex (file=0x604630
 "test_mov_windows", f=0x401401 <edgedensity>, parameters=0x0,
 raster=0x604270 "landuse96_28m",
 >     output=0x604650 "rli.mov_wind") at daemon.c:208
 > #3  0x00000000004013fa in main (argc=4, argv=0x7fffffffdec8) at
 edgedensity.c:70
 > G65:history > valgrind --tool=memcheck  $CMD
 > ==14113== Memcheck, a memory error detector
 > ==14113== Copyright (C) 2002-2010, and GNU GPL'd, by Julian Seward et
 al.
 > ==14113== Using Valgrind-3.6.0.SVN-Debian and LibVEX; rerun with -h for
 copyright info
 > ==14113== Command: r.li.edgedensity map=landuse96_28m
 conf=test_mov_windows output=rli.mov_wind
 > ==14113==
 > ==14113== Syscall param write(buf) points to uninitialised byte(s)
 > ==14113==    at 0x5A028D0: __write_nocancel (syscall-template.S:82)
 > ==14113==    by 0x54B861C: send (ipc.c:31)
 > ==14113==    by 0x54B5EEA: calculateIndex (daemon.c:167)
 > ==14113==    by 0x4013F9: main (edgedensity.c:70)
 > ==14113==  Address 0x7feffc8d4 is on thread 1's stack
 > ==14113==
 > ==14118== Conditional jump or move depends on uninitialised value(s)
 > ==14118==    at 0x54B9214: RLI_get_cell_raster_row (worker.c:286)
 > ==14118==    by 0x4017D1: calculate (edgedensity.c:189)
 > ==14118==    by 0x4014C3: edgedensity (edgedensity.c:95)
 > ==14118==    by 0x54B8E40: worker (worker.c:192)
 > ==14118==    by 0x54B5BEA: calculateIndex (daemon.c:102)
 > ==14118==    by 0x4013F9: main (edgedensity.c:70)
 > ==14118==
 > ==14118== Syscall param write(buf) points to uninitialised byte(s)
 > ==14118==    at 0x5A028D0: __write_nocancel (syscall-template.S:82)
 > ==14118==    by 0x54B861C: send (ipc.c:31)
 > ==14118==    by 0x54B8EA5: worker (worker.c:206)
 > ==14118==  Address 0x7feffb364 is on thread 1's stack
 > ==14118==
 > ==14113==    by 0x54B605A: calculateIndex (daemon.c:208)
 > ==14113==
 > ==14118== Invalid write of size 4
 > ==14118==    at 0x4E5D630: G_set_c_null_value (null_val.c:147)
 > ==14118==    by 0x401726: calculate (edgedensity.c:176)
 > ==14118==  Address 0x6278f04 is 0 bytes after a block of size 2,004
 alloc'd
 > ==14118==    at 0x4C2380C: calloc (vg_replace_malloc.c:467)
 > ==14118==    by 0x4E3D66C: G__calloc (alloc.c:77)
 > ==14118==    by 0x4E3D843: G_allocate_cell_buf (alloc_cell.c:66)
 > ==14118==    by 0x4016DC: calculate (edgedensity.c:169)
 > ==14118==
 > ==14118== Invalid read of size 4
 > ==14118==    at 0x401A72: calculate (edgedensity.c:242)
 > ==14118==  Address 0x5eb8d64 is 0 bytes after a block of size 2,004
 alloc'd
 > ==14118==    by 0x54B8D51: worker (worker.c:167)
 > ==14118==
 > ==14118==    at 0x401975: calculate (edgedensity.c:228)
 alloc'd
 > ==14118==
 > ==14118==    at 0x401A93: calculate (edgedensity.c:244)
 alloc'd
 > ==14118==
 > ==14118==    at 0x401AEC: calculate (edgedensity.c:250)
 > ==14118==  Address 0x5eb9584 is 0 bytes after a block of size 2,004
 alloc'd
 > ==14118==
 > ==14118==    at 0x401C87: calculate (edgedensity.c:316)
 alloc'd
 > ==14118==
 > ==14118==    by 0x401829: calculate (edgedensity.c:197)
 > ==14118==  Address 0x6279b14 is 0 bytes after a block of size 2,004
 alloc'd
 > ==14118==    by 0x4017DF: calculate (edgedensity.c:192)
 > ==14118==
 > --14118-- VALGRIND INTERNAL ERROR: Valgrind received a signal 11
 (SIGSEGV) - exiting
 > --14118-- si_code=1;  Faulting address: 0x86291FA8;  sp: 0x40327be10
 > valgrind: the 'impossible' happened:
 >    Killed by fatal signal
 > ==14118==    at 0x380362F9: vgPlain_arena_malloc (m_mallocfree.c:245)
 > sched status:
 >   running_tid=1
 > Thread 1: status = VgTs_Runnable
 > ==14118==    at 0x4C244E8: malloc (vg_replace_malloc.c:236)
 > ==14118==    by 0x4E3D59E: G__malloc (alloc.c:37)
 > ==14118==    by 0x54B9641: avl_make (avl.c:43)
 > ==14118==    by 0x401BD6: calculate (edgedensity.c:279)
 > r.li.daemon/ipc.c:
 > int send(int pipe, msg *m)
 >     int check;
 >     /* write on pipe */
 >     check = write(pipe, m, sizeof(msg));
 >     if (check > 0)
 >       return 1;
 >     else
 >       return 0;
 > Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/2024#comment:28>
